1 - 5 of 5 Posts
Well me and three of my friends installed my system today and everything worked fine.Well i was driving home and my deck shut down and stayed off. Well when i got home it still didnt work.Than i shut off my car and left the key in and it worked. Like 30 min later i went out and started my car and it worked fine.When i was about to go home ,it shut down again. It works fine with the car off but when i turn it on,sometimes it shuts down. Also when i accelerate i hear a little hissing sound. If you guys can help me i would be very greatful.
Re: I need some help with my system (VRSexed)
yeh its DEF a shortage in the wiring or one of your fuses is blown, as far as the hissing noise you goin to have to buy a noise filter or someone mentioned to me if i changed my spark plugs but i doubt that would work.
i have the same problem but i baught a noise filter for 15 bucks and i never had a chance to put it in but i know it definently improves the sound.
good luck
· Banned
Re: I need some help with my system (IIIGTIVR6)
Check to see if your fuse is loose, that was the problem with my deck. Just push in all the fuses under the dash making sure they are all in all the way. I bet it fixes it... http://****************.com/smile/emthup.gif
Re: I need some help with my system (late_apex)
As far as the hissing noise goes.. it's probably just what they call "road noise." I hooked up my system and luckily I didn't have this problem, but to fix it I was told that you should check all the wiring and make sure that it is not touching on any of the bare metal of the car. (except, of course, the ground) Also make sure that your power line and ground are leading in different directions and have some space in between them/not touching.
1 - 5 of 5 Posts
