i need some technical help please
283 Views 1 Reply 2 Participants Last post by  DaBlackJetta
hey guys i am getting my second ecu hopefully this thursday and so what i am going to do is take it to a shop and get it i guess programed so i can make it work with my car. but after i have him program the ecu for my car i am taking it out and getting it sent away to be chipped so they help i need is that when it gets sent back to me will i have to have it programmed with a vagcom again or will i be able to just switch them when i get it back cause i am doing the codes with the vagcom now. what will i have to do cause i am going to use the vagcom to code it friday to make sure it works with my car than i am sending it off so do i need to have to use the vagcom every time i switch ecu's thanks guys.
_______
Status
Not open for further replies.
1 - 2 of 2 Posts
Re: i need some technical help please (blueabdjetta)
Please, no cross posting.
Also.. to answer your question (or what I think your asking anyway) is no, your ECU will already be coded to your car. You can send your ECU away and have it chipped... when you get it back, it will work fine in your car.
1 - 2 of 2 Posts
Status
