Re: I need someone with Welding skills (Commocozy)
fusor is ok for doing plastic work, but imho you are better off welding in your steel filler panels especially when concerning things like deck lids, shaving side trim, etc. I've personally used fusor & it's equivilant there of many times, however I have had some good and some bad experiances, so for now I just use it for gluing door reskin jobs in addition to mimicking the factory plug welds if it'll be a conourse style restoration. Custom jobs get the edges welded & glued in the flats.
then again..it's not like i know what the hell i'm doing.
as far as what gauge steel for welding in patch panels on newer crap I tend to use 18-20 gauge, match whatever gauge your patch is to the gauge of the panel. I personally like cold rolled ak steel, as it's easier to form on the wheel / power hammer / by hand if you're going for a metal finished repair anyway. Otherwise even just basic cold rolled will be fine and get the patch as close as possible so you just have to skim the repair with filler. no biggie.
all side trim, rocker trim, etc. shaved. new wheel house, etc.
