1 - 20 of 20 Posts
my bumper side marker lights that is. I've been thinking about it for a while now, but I have to give props where it's due, if I hadn't seen Nicole's (VdubGirl) car that Derek (countblah.............) worked on, I may not have done it.
here it is, just needs prime and paint, hopefully I'll make it down to my buddies shop tomorrow.
before, smoked -
weld weld weld -
fill fill fill -
sand and smooooooth -
hope you like, I do. I'll have some full car pics later after paint.
thanks -
Banned
Re: i shaved - check it out. (dubtrixT)
Just a suggestion.. to insure flatter work that's closest to the natural contours of the bump sand in a criss cross patter http://****************.com/smile/emthup.gif Looks great.. looks like you plastic weld better than me
Banned
what process do you use to weld the plastic? impulse, ultrasound, or a gas
Discussion Starter · #7 ·
Re: i shaved - check it out. (baomo)
thanks for the comments derek (countblah) - will criss cross from here on...
as per plastic welding, I use a plastic welder, also known as a heat molding iron, just like the one countblah posted above.
thanks -
Banned
Re: i shaved - check it out. (CountBlah.......)
sometimes i forget.
i was thinking about a handheld ultrasonic like 30kHz, not that its structural but figured it would be smoother than a contact weld.
Re: i shaved - check it out. (1SickWhtDub)
wow man, good job. all this shaving is making me giddy. i can't wait to do mine. http://****************.com/smile/emthup.gif
Re: i shaved - check it out. (5ven3)
Quote, originally posted by 5ven3 »
nice shave... http://****************.com/smile/emthup.gif
ROFLMAO
Re: i shaved - check it out. (lil mike)
bondo is no good for plastic. http://****************.com/smile/emthdown.gif
foser 142, tougher to sand but better
Banned
Re: i shaved - check it out. (Darrell)
Quote, originally posted by Darrell »
bondo
"Bondo" is no good for anything.... but modern polyesther fillers will stick to just about anything.. I use Evercoat Rage Gold
Discussion Starter · #18 ·
no bondo here either Darrell - I used evercoat rage as well, though mine had a blue cream hardner.
as long as the piece is prepped right, as in no paint left on it, the filler will stick. The other thing to remember is that you only need a skim coat of filler anyway, the weld (which is re-inforced from behind) is where you get the strength from. Not too much filler is needed.
thanks for the words all.
1 - 20 of 20 Posts
