2
Re: i want to go lower!!!!!!!!!!!!!!! (CDNCT)
quote:[HR][/HR]first off, how long has your suspension been on? you gotta let it settle.
second, you can get the front about a 1/2 inch lower by getting lowering spring caps or lowering bushings.[HR][/HR]
Remember, quality suspension parts will not "settle". Yes, the moment you first do your install, lower your car, and drive it around the block, it will settle a bit. But, after that, it should not come down at all. It sounds like he's had his kit on for awhile, so I'd venture to say that it's as low as it's going to get.
Coilovers are really your best bet for wanting to go real low. Get a good quality set of coilovers, like H&R, KW, etc. and put it on its nutz! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
