Re: I wonder where engine RPM limit is??? (gintaras)
the cams/airflow determine your redline...
Theres no point of revving your motor to 7500 or 8000 rpm's if the turbo is gonna poop itself, and the car will not be making any more power (due to lack of breathing)..
Remember the old 16V, well folks take those motors into the nether-rpm range, they actually continue to make power if worked(cams/pnp) all the way up there.
But to answer your question, the valve springs, and hydraulic lifters will probably start to float valves around ~~7500, There's a good reason folks stick with solid lifter heads with all the troubles they bring..
[Modified by mrkrad, 9:48 PM 2-10-2002]
