1 - 3 of 3 Posts
when i start the motor the engine die after 30 secondes but if i disconect the blue sensor the engine dont die anymore but i'm not able to start it without the bleu sensor when i try to start it the engine make some smoke and its not funnny for eyes ..... please help me fast
Re: idle and blue sensor problem (TBT-PassatG60)
ok i make some test tonight i have two blue sensor in the shop one are darker than the other the first one are blue like the end of the harness and the other are like royal blue.. by the way the motor die with the two sensor so i have check the length of the ecu vacuum and he have 94.5 cm i know he suppose to be 1m long so i will change it tomorrow by thw way the motor die only when is hot ?? anyone have idea ???
1 - 3 of 3 Posts
