Ok, car starts up fine and settles into a normal idle for about minute, then the rpm's all of sudden start revving between 1 and 2 thousand, just like a formula one driver would do before a start, only fast and without stopping. First, I thought it was a simple vacuum leak, but everything checks out fine. Since it takes about a minute to start to happen, it can almost rule out a vacuum leak as that would start immediatly. Could it be the coolant temp sensor malfunctioning? Seems unlikely it's a TPS or an idle stabilizer problem, as they would most likely show immediatly too. Any suggestions?
Steve
91 Passat
Steve
91 Passat
