1 - 5 of 5 Posts
when I am sitting at a stop when the caddy is warm, or hot, the idle will slowly creep up until I tap the throttle.. than it goes back down to perfect and then do it again slowly... Do you think a sticky throttle plate would cause this? or something else?
it starts fine when cold and runs great other than the idle climb
Thanks in advance
[Modified by Big CADDY, 4:52 PM 2-11-2002]
Re: Idle increase question (Big CADDY)
well... first thing i would do is clean the TB and such. from there if it continued i'd be checking for possible vacuum leaks...
1 - 5 of 5 Posts
