Re: idle seems to high (dredward)
That motor has ECU controlled idle speed. If it's as high as you say, there's something seriously wrong -- such as a substantial vacuum leak -- which must be fixed. It may have some adjustment in Adaptation Channel 01, but the adjustment range (if it's there at all) is normally something like +/- 50 rpm, IOW not enough to get the idle speed in spec.
-Uwe-
