Re: idle speed adjustment screw (just g60)
quote:[HR][/HR] so if my screw is in almost all the way in, i just changed my computer chip, and my idle is going up and down at like 600-750 and i give it just a little throttle to 800-900 it sounds great, what do you guys think?[HR][/HR]
Lots of things could be causing your low idle. I doubt it has much to do with the idle adjustment screw, since they seem to be an all or nothing thing - ie either it is there and plugging up that hole, or it is missing and causing problems. Check over all of your vacuum hoses, little leaks through cracks or frayed hoses can screw with your idle.
-Nate
