Ok, so I consider myself to be very knowledgeable about the CIS system. I have owned my 1987 cabriolet for about 5 years now. I built an ABA engine and put a Eurospec 8v CIS head on it. I drove it for 5,000 miles or so with no issues.
Well, the other day I got a TT adjustable cam gear and installed it and made a rookie mistake. I used the wrong timing mark. I bent the #1 exhaust valve (I have a TT 276 cam and the head has been shaved, so yes it is an interference engine now.). I compression checked every cylinder and 2,3, and 4 were all at about 140 psi. #1 was at about 30 psi.
I pulled the head off, changed the #1 exhaust valve and reinstalled the head with all appropriate new gaskets, etc.
It would not start when the cam was properly timed, it will only start if the cam is one tooth retarded. It idles at 1300 rpm and will not rev past 2000. I have tried a tooth in either direction and this is the best I can do.
I have check for vacuum leaks, there are none.
Each fuel injector is spraying a good pattern.
Each spark plug is sparking.
The plug wires are going to the correct plugs.
The ignition is set to about 10 degrees BTDC.
So, I am lost. Nothing aside from the #1 exhaust valve is different. It ran fine before, and now it just won't rev past 2K.
Any advice would be appreciated. I'm leaning toward something unrelated and coincidental has failed. Distributor cap? Ignition Coil?
