Re: If i switch ECUs (roly)
not sure but i would definitely drive the car around for a while just to make sure ...
theoretically if the ecu has already been driven in another car with the chip in it.. then it should be used to the chip... but each car is different and depending on the info the ecu gets from the sensors on your car it may or may not adjust the output accordingly...
