If you thought NASCAR was "bad", check out the new DTM
1091 Views 20 Replies 11 Participants Last post by  FiveAinOne
So people often complain that NASCAR "Stock Car" racing is a little "wrong" since the cars are nowhere near showroom stock condition. For instance, you can't walk into any Ford dealer and walk out with a RWD V8 Taurus, etc....
Well, I was perusing Audi's motorsport site and followed a link to the ABT website. ABT enters Audi TT's (Called Audi TT-R's) in the new DTM (Which now stands for German Touring Masters instead of Deutsche Tourenwagen Meisterschaft" (similar but diffrent)).
Anyway, check out the ruls for the DTM:
"Rear wheel drive is mandartory in the DTM, as is the uniform six speed sequential gearbox supplied by the specialist company X-trac to all teams."
So how is possible for Abt to enter 4 Audi TT's into a rwd six speed competition?
They modify the hell out of them!
RWD Six speed sequential trannies being pushed around by Abt V8 DTM engine, front longitudinal, 90 degree cylinder angle, cylinder spacing 98 mm, four OHC, time-chain good for 450 HP
Go here and click "DTM" for more info:
http://www.abt-sportsline.de/mainframe.asp?lang=gb&e1=-9&e2=1&iframe=navigation.asp&mublic/gb/motorsport/motorsport_start.htm
If you go to the 'Abt TT' link within the Bt site, scroll all the way down for Technical data.
See less See more
1 - 20 of 21 Posts
Re: If you thought NASCAR was "bad", check out the new DTM (PsyberVW)
Hmm well at one time these were the most technolgically advanced cars in the world. They had heavier than lead blocks in the truck area with hydrallic rams that would shift the weight over the axle, and side to side, to effect the handling depending on if you were accelerating, turning, braking, etc. Not to mention a LOT of carbon fiber (bodies, maybe parts of the chassis, they might even have composite monoques). What displacement are these motors?
J.
[Modified by Crazyquik, 4:11 PM 12-2-2001]
Re: If you thought NASCAR was "bad", check out the new DTM (Crazyquik)
Motor Specs:
Displacement 3.998 ccm
Bore & Stroke 93 mm x 73,6 mm
Compression 13,6:1
Power Output: ca. 331 kW (450 hp) at 6,800 rpm, Air intake restrictor 2x28 mm diameter
Max. torque ca. 500 Nm at 6000 rpm
I wasn't knocking the technology at all, I was just comparing the race cars to NASCAR since many people say that the "Stock cars" in NASCAR are from off the shelf "stock" in comparison to the road-going models they represent.
BTW- I'm amazaed the fit a V8 in there! I thought a 1.8T took up enough room as it was!
See less See more
Just a little note, you can get a RWD V8 Tarus . If you walk into a Ford delaer in Australia
You can also buy a V8 RWD Tarus from Ford Racing Track use only of course!
See less See more
I have two problems with NASCAR, nearly all their races are on ovals and they constantly reinvent the rules to regulate the hell out of the cars so that no one ever has a real advantage. The cars themselves are pretty cool.
Re: If you thought NASCAR was "bad", check out the new DTM (PhilHVW)
I can deal with the ovals, because like the Roman chariot races in the Coliseum (and other similar events of the day) the spectator is the focus, and it's easier for the spectator to see the event on an oval (especially the smaller ones). It's also easier to set up at fairgrounds and smaller venues around the country, so amateurs can easily get involved and move up the ranks.
As far as Stock Car, the term is to differentiate production looking vehicles from modifieds and sprint cars. Since the term goes down through the classes to include Foreign Stock racing (where you'll find many Rabbits and Sciroccos, as well as Toyotas, Nissans, Volvos, non-rotary Mazdas, and more...), it has nothing to do with whether Ford offers a RWD Taurus.
See less See more
Those specs looked cool untill it said they had intake restrictors
No wonder they only make 450 hp, you think they'd let them run 600+.
See less See more
I hate NASCAR. They could at least use a production chassis.
Re: If you thought NASCAR was "bad", check out the new DTM (RJetta8V)
quote:[HR][/HR]I hate NASCAR. They could at least use a production chassis. [HR][/HR]​
While showroom stock is a competetive set of classes in SCCA road racing, the top classes aren't stock either. DTM used to be production chassis, but advancing speeds and safety issues generated sillhouete cars, too.
NASCAR's top classes used to have stock chassis, until teams tried to get the extra edge, and people asked for safer cars (in the late '60s, the cars were just as fast, but with chassis considerably closer to stock. But not as safe at 200 mph as a modern race car.) Make no mistake, these are purpose built race cars, designed to keep the racing fast and close, to get the most out of teamwork and driver skill to win any given event.
NASCAR is a form of autoracing
Sounds better than carbeuraters and ovals.
Re: If you thought NASCAR was "bad", check out the new DTM (Chris V)
The cars will go thru a major change........as soon as one goes up into the crowd
Untill then the cars will get faster and the walls thicker, and all its going to do is smash the drivers flatter (in lay terms).
J.
See less See more
Re: If you thought NASCAR was "bad", check out the new DTM (dolemite)
Oh how I pitty! Man NASCAR may not be the best but to ask if its a form of autoracing!
You guys are way to harsh on NECKCAR. SO let me get this straight. You think its stupid to watch thirty cars with thousands of Horsepower going three and four wide rubbing fenders screaming big blocks pushing 200 MPH all because they go in a circle.
Yet you think the VW Polo is a bad machine. Hummm!
See less See more
Don't lose sight of what "modern day Nascar" is all about. Money!! Race on Sunday/ Sell on Monday could never be more true. Don't spend too much time asking whats wrong with somthing when its making tons of money. Obviously there a number of folks that like Nascar, Iknow the sponsors sure do. I hate watching it on TV, but before you knock it you need to see one in person. As the cars approach you, 3 wide on the track, it sounds nothing like V8's, when the pass there is a distinct V8ish/whistling noise that is like non other. TV does it no justice!!
Re: If you thought NASCAR was "bad", check out the new DTM (TLP)
The new DTM rules are a result of the failings of the series in the past. In 1993 FIA regulated the different touring car classes, to make it easier for the manufacturers to build a car that could be used in different countries. There was a close to production series with 2 litres displacement and no bodykits or electronics and there was the class 1 with AWD, bodykits, etc. The DTM up to this year was something in between, so they opted for Class 1, while everyone else was opting for the other class.
After a few years, both series got problems. The cost in class 1 aka the DTM got out of hands and in 1996 the manufacturers opted out.
The class2 (2 litre cars) never caught on with the public, because the cars were very unspectactular and improvements also came at high costs, due to the strict rules.
So when the DTM was reinaugurated in 1999, the manufacturers wanted something spectacular and yet at low costs. They voted for a V8 (sound) and lots of common parts (like the gearbox).
When the last DTM got busted, the cars were far from production cars, made mostly from carbon fiber.
The DTM IMHO was best around 1989 with the Audi V8, BMW M3, Mercedes 190E 2.5-16 Evo and the (highly unsuccesful) Opel Omega and a privately engaged Ford Mustang.
See less See more
Re: If you thought NASCAR was "bad", check out the new DTM (Eolair)
How'd the Mustang do? It probably started out as a Trans-Am series Stang.
Actually, the one he was talking about was similar to what you would have seen in an SCCA Showroom Stock series... very slow, compared to the AMG cars. They would have done better even then using a Saleen racing version.
I remember watching that era on TV (and I agree about it being amongst the best), and seeing "production" BMWs and Mercedes with 17" centerlock wheels... This was stock? No....
quote:[HR][/HR]Actually, the one he was talking about was similar to what you would have seen in an SCCA Showroom Stock series... very slow, compared to the AMG cars. They would have done better even then using a Saleen racing version.
I remember watching that era on TV (and I agree about it being amongst the best), and seeing "production" BMWs and Mercedes with 17" centerlock wheels... This was stock? No....[HR][/HR]​
I didn´t say these were production cars, but the cars were related to production and still were spectacular.
The Mustangs were run on a very limited budget and could in no way compete with the manufacturer backed cars, but those were a nice point of color.
AH but fret not the Merkur XR4ti or Sierra cosworth was kickin some serious ass on the 190 EVOs in the BTCC runs. The coolest race of all IMHO was at SPA when I think 89 they had many of the touring teams including Ludwig running their cars, evo 190s and M3s galore batteling Cossie's it was a better day then for racing and for enthusiast as you were able to buy what was raced.
hehe. i didnt mean to knock NASCAR in any way. I was just relating the rules of DTM to NASCAR.
I understand the philosophy of "stock car" racing and agree with it wholeheartedly. I just read many threads on here about how NASCAR cars aren't "[factory] stock" and "primitive" for using carbs, etc... All the while the famed DTM is doing the same thing
On the other hand, I would like to see more "/slightly/ modified prodcution vehicles" in the popular race series. While I do enjoy the spectacle of both NASCAR and DTM, I believe it would be both equally exciting AND lucrative for sponsors, if these types of vehicles made it into mainstream motorsports.
For example, after watching a NASCAR race, how easy/applicable is it for you to run to an auto parts store and buy the same parts the race teams use for your late model Contour SVT? Aside from spark plugs and batteries, maybe eibach springs/dampners, what else is there?
And if you are a NASCAR fan who drives an Accord to work, you're already hopeless...
On the other hand, imagine watching a race team using Nuespeed and Autotech parts on a production vehicle "exactly" like the one in your driveway. I dunno, i just think there is soo much possibility there for an increased base of motorsports fans. Part of what makes touring car racing popular is that the cars look so much like the everyday cars we drive. People can relate to these cars much easier.
That can only mean more $ being put into the industry and (hopefully) better products coming out.
I'll use the R/C Industry as an example. Touring car racing is probably becoming as popular (or more popular in some regions) as off-road racing. The reason being that people can buy kits which look similar to the cars they drive in real life. NASCAR-style oval racing has all but dissapeared as the drivers moved to Touring car classes. Even begginers in the hobby gravitate towards to familiar shapes of the touring car kits. This class has practically single-handedly revitalized ALL classes of the R/C industry in the past 5 years. This has led to incredible amounts of funding being able to go into ALL classes for researcha nd development which in turn led to the production of kits with standard features, lower costs, and less steep learning curves. This benefits both the consumers AND the manufacturers.
While I don't wish any ill-fate to the BUSCH/WINSTON CUP Nascar series or DTM, I see a market of fans and consumers who could all benefit from the "mainstreaming" of "'slighty' modified production vehicles instead of only making purpose built specialty vehicles the only choice in mainstream motorsports.
It's a vicious cycle, but once it's broken I gaurantee the motorsports world will prosper like never before, both in the aftermarket and in-house. NASCAR gets priority because it's most popular. NASCAR is most popular because it gets the most coverage (and priority).
The media is a sneaky bastid, but I gaurantee it is not the slave. That is all reverse psychology. If a media station truly wants a product to succed, it will make it happen. The job is that much easier when you have a winning formula to begin with. In our case, the American Le Mans Series is right here, right now. Trans-AM. Even Speedvision GT. Now that FOX is in cahoots with SV, lets see some Speedvision GT, World Challenge Rally, etc.. on the local FOX stations. Make it happen!
As for that comment about RWD V8 Taurus's
I vote we conquer Australia once we're done with Canada
See less See more
4
1 - 20 of 21 Posts
