  • Rejoining the VWVortex Community - Please review the following thread: Here
1 - 1 of 1 Posts
Discussion Starter #1
Today I was replacing rear rotors and pads on an '01 A4 Quattro. The piston turned freely but it just wasn't going in at all.
I googled this and found others with the same problem, but no solutions (other than rebuilding or replacing the whole caliper.)
So I thought, could the parking brake be stuck, even though the lever was down? I put some penetrating oil on the levers on the caliper and got it moving, then the piston went in by turning.
I also thought about loosening the cable adjustment up front. I can imagine if it's been adjusted tighter to compensate for worn pads, it might need loosening for new ones. I might check that before driving, but I still have the front to work on.
1 - 1 of 1 Posts
