Ignition Advance Table For Stock VR6
14117 Views 9 Replies 5 Participants Last post by  need_a_VR6
I need a complete ignition advance table for a stock VR6 AAA OBD2.
I'm in process soon tuning my MS2 v3 for my OBD2 AAA VR6. I would really like someone with an msq. file with this information but I'll take anyone with GOOD information. I need to know the ignition advance for a stock VR6 so I can populate my in-boost advance. If anyone has a good Vag-Com xml. with rpm that would be help full.
1 - 10 of 10 Posts
Re: Ignition Advance Table For Stock VR6 (VOLKS-MAN)
This is very close to GIAC's OBD1 tune:
See less See more
  • Like
Reactions: 1
Re: Ignition Advance Table For Stock VR6 (need_a_VR6)
Would you say this is a safe table to start with?
Everything in that map is good on 93 octane with a MK4 head gasket.
The cells from 2200-4000rpms up to about 50kpa seem quite advanced. Was this for cruising conditions and fuel economy?
Yes, exactly.
FV-QR
Yep.
Thanks for this! 🙌🏼
bringing this back from the dead. where did you find this? thanks
I made it based off of vag com datalogs for rpm/timing and some guesses using a ms1 to correlate maf/map readings. It works pretty well.
1 - 10 of 10 Posts
