Re: ignition control module (JerseyBoy)
The tach jumping is as a result of a poor ground. On my 16v I have a loose ground, and if I have shake the ground while the key is on, the engine doesn't even need to be running, and the tach goes crazy. Maybe when you replaced the module you accidently moved one of the grounds.
