Re: Ignition switch woes (Hitesh)
That may help you in the short run, but that's not the only ignition switch problem. If it's getting flaky, the main power circuits in your car will start to come and go. You can't put off the ignition switch job forever, so consider getting it over with now.
Search on this forum, archived posts, terms such as "ignition switch" "push button", "start switch", etc. You may have to read deep into each thread before you find something. Try also the Golf/Jetta 2 forum.
