Re: I'm a girl, so excuse my stupidity...whats wrong with my car? (litljenarey)
Clean the ISV (idle stabilizer valve). Its the metal cylinder on top of the valve cover with a 2 or 3 wire plug( it buzzes when the ignition is on but the engine is off). there should be 2 plastic / rubber hoses running into it. Dont unplug it with the ignition on, you can damage the computer. remove the hoses that go into it and spray the inside of it with Carb Cleaner. hook it all up and if that didnt help try unplugging the 02 (oxygen) sensor. On the back of the engine where the exhaust comes out there is a sensor, the wires should lead up somewhere near the brake fluid resirvoir. unplug it, its either a 1 wire or 3 wire harness. Drive the car with the 02 sensor unplugged and note any changes.
