I'm getting so FRUSTRATRED!!
438 Views 12 Replies 12 Participants Last post by  NVmyVW
I just went out to fix my reverse lights, while I'm out there I notice the plastic rain catcher, that collects the water from the windshield is gone. GONE!! How would that come out??? It's under the hood. I tell ya if it's not one thing or another with this car. I just want to know what kind of problems everyone else has. I know I am not alone here.
Here is my list in just 3 months!
1. Water leak (left it outside the first weekend, 2 inches of water in the car)
2. No brake lights
3. Cracked my headlight lense (ruined 2 bulbs)
4. Broken fog lights
5. Broken spoiler
6. Power drain 1 battery and now I have no powerwindows
7. Broken reverse lights
8. Leaks powersteering fluid
9. The day I drove it home, the back lisense plate pannel came off. I drove for 2 hrs looking for it
10. Everytime I turn on the rear defroster I blow a fuse
11. Lost the center caps on 2 of my brand new Team Dynamic rims
12. Not car related, but my amp caught on fire
13. Passenger side marker just fell of somewhere last weekend
14. Because of the broken reverse lights and broken defroster I ran into a blazer that was parked behind me on my second day of ownership
I don't know I might just be ranting, but I am getting sick of it. Although for some reason I still love this car
See less See more
3
1 - 13 of 13 Posts
Re: I'm getting so FRUSTRATRED!! (nuemerik)
Yup lots of stuff always and forever f--up on these bad boys
1. Water leek on passanger side
2. Wonderful paint job! http://****************.com/smile/emthup.gif (j/k
3. Dented up fender parellel parking high
4. Spoiler broke long time ago
5. Interior light doesn't go off for like 10 days
6. Fan control modual is fried
7. Oh yeah no f---ing A/C...forgot about that one
8. Random holes in part of the interior (stupid PO)
9. No foglights
10. Man I forgot about all these things....its like as long as it runs i dont really care.
See less See more
5
Re: I'm getting so FRUSTRATRED!! (VeeDubBBoy)
Wow.. after listening to your guy's problems I am increadibly happy mine hasn't suffered the same fate...... yet. Spoiler still works, sunroof still works, good interior, only things I can complain about is one broken fog light and the highest setting on the heater doesn't work
Here's my list, after owning it for only 6 months or so...
1. Sunroof rack needs to be replaced ($500)
2. Rear defrosting needs repairing ($???)
3. No switch for foglights ($???)
4. Need new tires ($500)
5. Coolant leak ($???)
I know, it's pathetic, but the rear defroster and the broken sunroof really bugs me, plus, I've wanted to do so much to my car, since it's mostly stock, but I've waited for so long and nothings happened, I have neuspeed springs for it, but haven't found the time to equip them on my C.
See less See more
i feel ya, less than 6 months...
1)new tranny
2)new Clutch
3)new coil pack
4)new engine speed sensor
5)full tune up (not really something going bad, but definately a chunk of money)
6)the usual sunroof problems
7)the usual leak in the passenger floor
8)most recently..(Yesterday) ECU?!?!?!?
i hardly have the money or the time do add anything aftermarket with all the time and money i use fixing it.
but when it all comes together working for a week or two (j/k its usually a little longer than that!) I Wouldnt trade it for anything!
Cheers to the C
[Modified by BigStuster, 8:07 AM 2-7-2002]
See less See more
3
Re: I'm getting so FRUSTRATRED!! (BigStuster)
ok, the Corrado didnt come with a raintray under the hood.... The only ones that have been in corrados are the A2 ones that people put in on their own.
Re: I'm getting so FRUSTRATRED!! (B(C)orrado)
quote:[HR][/HR]ok, the Corrado didnt come with a raintray under the hood.... The only ones that have been in corrados are the A2 ones that people put in on their own. [HR][/HR]​
there is the small tray just over teh ECU however... mighta meant that..
anyway.. here's my list.. owned the C since september..
1)rebuilt charger from Gruven
2)New brakes + rotors (zimmerman x-drilled + mintex reds)
3) New guage cluster (after i broke the original one
4) New O2 sensor... (putting that on in the parkin lot as we speak)
5) New pass-front fender (P.O. got hit in a parkin lot)... should be coming soon
6)No AC
7)Cruise doesn't work...
that's all so far... let's hope it stays that way
nate
See less See more
2
WOW i remember those days
My list was A LOT longer
ok here are a few things i know about
as for the rain catcher thing....get one from an A2 jetta/golf takes some heat gunning but it fits and looks a LOT better
the water leak is the air vent under the windshield on the pass side. either the drain hole is clogged or the gasket under the screen over teh vent is bad...check those
cracked headlights....i have an extra set just missing the trim around the lens that have had the brackets ghetto fixed(works fine though) email me if you want em cheap.
how is your spoiler broken? my guess would be either the motor($35) or the assembly just needs to be regreased(2 hours or your time)
power streering leak is probly the power steering rack(this kinda pricy unless you can put it in yourself)
as for the rear lights check the grounds and the reverse light check the switch in under the shifter
and the AMP catching fire.......NICE.....dont think anyone else has done that http://****************.com/smile/emthup.gif
hope that helps.....
See less See more
2
well i just bought a 1993 SLC VR6 with 130,000 for $5800
Replaced all rotors and pads completely myself- ($400)
Replaced Cap and rotor and plugs myself ($80)
I have a coolant leak from Aux water pump ($135 on order)
Have exhaust leak ($400 neuspeed catback on order)
Shocks and Springs...old original ($440 neuspeed spring and Bilstein sport from CRAZY-LEGS)
Water leak passenger side.
Car is in the body shop getting resprayed passenge door and dings patched...($500)
I"M SCARED TO KNOW WHAT IS GOING TO GO NEXT!!!
See less See more
Re: I'm getting so FRUSTRATRED!! (azartman)
The rain catcher that I am talking about, goes along the winshield. I'm sure all of you have it. It goes over the wiper motor and the vent that leaks. It's broken up into 2 sections the smaller one goes over the vent, and larger one extends the rest of the windshield. I have fixed most of my problems, but it seems that more and more come up everday! So if any of you have a parts corrado and you still have the plastic piece that I lost email me.
Wanna play the Corrado game?Gotta pay pal.
Just look at you weeners,blaming stuff not even the cars fault,on the car.Sell now and live happy.
quote:[HR][/HR]The rain catcher that I am talking about, goes along the winshield. I'm sure all of you have it. It goes over the wiper motor and the vent that leaks. It's broken up into 2 sections the smaller one goes over the vent, and larger one extends the rest of the windshield. I have fixed most of my problems, but it seems that more and more come up everday! So if any of you have a parts corrado and you still have the plastic piece that I lost email me.[HR][/HR]​
The rain catcher is not two pieces. It looks like it should be but it isn't. They only came with the small peice on the passenger side.
Re: I'm getting so FRUSTRATRED!! (KinetikSLC)
Im a grand deep into repairs have just now started to buy aftermarket stuuufff
Eibach springs and Bilstein sports- 670
TT 2.5 inch exaust- 500 with black powder coated tip
Brembo rotors and mintex pads- too much and not yet installed
But before this stuff i basically replaced all the gaskets and pumps i nthe entire car
See less See more
1 - 13 of 13 Posts
