1 - 3 of 3 Posts
Re: im going nuts with 16v digi 1 (killacoupe)
Brown is ground! Why did you hook it to the ignition! Lol, trace your wires... check your ignition wire for continuity to ground... and look for a short or something somewhere. Good luck!
Did you tap any wires off of it for the swap? Did you just install the engine harness?
Modified by gtibunny8v at 4:07 PM 6-30-2003
1 - 3 of 3 Posts
