I'm thinking about buying a Tacoma and putting on a TRD Supercharger...
1248 Views 20 Replies 15 Participants Last post by  Ted
I have my eye on a new Tacoma TRD extracab V6 4x4 5-speed with SR5 package and am thinking about putting on the TRD supercharger. Anyone have any comments, experiences with the supercharger? I love Toyota trucks...they kickass and are dead reliable!
1 - 20 of 21 Posts
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (Ted)
No experience with the V6 or SC, but I used t work for an auto parts place that had a new Tacoma 4 cyl/5 speed as our delivery truck. Fun little thing. Could chirp second with NO problem, and even get third sometimes.
See less See more
2
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (Coolwhite Fox)
quote:[HR][/HR]No experience with the V6 or SC, but I used t work for an auto parts place that had a new Tacoma 4 cyl/5 speed as our delivery truck. Fun little thing. Could chirp second with NO problem, and even get third sometimes.
http://****************.com/smile/emthup.gif [HR][/HR]​
I can do that with my Datsun.
Oh, and my friend can do that with his MIGHTY MAX! He has REALLY low gears, like 2nd is as high as the first on my Jetta.
[Modified by RJetta8V, 5:02 PM 12-1-2001]
See less See more
3
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (RJetta8V)
Aren't there engine management issues with the supercharger? I heard there were some big problems with this stuff.
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (Rob)
quote:[HR][/HR]Aren't there engine management issues with the supercharger? I heard there were some big problems with this stuff.[HR][/HR]​
I would imagine that since it is a TRD supercharger, then they've probably already figured it out.
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (stl4310)
Why not just get a Nissan truck that already has the SC on it from the factory???
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (Rice_Box[Sentra])
Cuz I think the Nissan trucks look like a garbage truck from the front. Also, with the TRD supercharger, the Toyota will pump out more power than the supercharged Nissan will...and it looks three times better!
I would imagine that since it is a TRD supercharger, then they've probably already figured it out.[HR][/HR]​
Actually, TRD didn't do much of the development. They used the same company that did the Neuspeed supercharger (vice versa actually). If you do a search you will find that people have been having fuelling problems with the kit, having to install bigger injectors and engine management boxes to get it to run right. Not what I would expect of TRD stuff.
Go for it. http://****************.com/smile/emthup.gif I have the same exact truck, minus the supercharger. As for the Nissan, 210 hp/246 ft. lbs is not that impressive considering it's supercharged. It's a 3.3 liter sohc 12 valve asthmatic turd attached to an otherwise good truck with a tupperware body kit.
The 3.4 dohc 24v tacoma engine is a much better engine to start with. Add the supercharger and you get 260 hp/~300 ft. lbs.
See less See more
2
I had a 1998 Toyota Tacoma 2wd (not a PreRunner either) etra cab 3.0L V6, I had it lowered a month after I purchased it new, 1-1/4 Bell-Tech, paired the mild drop up w/ bilsteins fr&rr and added Bell-techs rear anti sway bar. Put a set of 18" konig Tantrum's with Khumo 712 ectas 255 45 18, added brembo slotted rotors to the front wanted discs in the rear but never could locate a source, ran 2-1/4 piping cat back, muffled via Borla and a Volvo C70 exhaust tip. I also wanted the scoop from the 4Runner but found out later the hoods don't swap and would be too $$$ to mold it in. This truck ran a 15.8 sec 1/4 in stock trim and would probably have been quicker if the rear end could hook up, i.e. roasting 1st-2nd--chirping third gear. Honda Civic Si's where no threat, let a loan a stock GS-R Integra I could almost hang with a Dakota 5.9 R/T till about 75 then I would get burned. later I added hotshots CAI and a K&N but really didn't drop the time. I decided that this mini truck had quite a-bit of potential and TRD had just launched it's first generation S/C at the time it was a whooping $3k installed pretty tough pill to choke, yet my best friend was a lot porter at a local Toyota dealer, he informed me that a kid worked at the dealer, purchased a stripped 2wd, 5/spd, V6 Tacoma added the TRD S/C and could not get it financed. At any rate he said I could come down and test drive it , knowing I was thinking about getting one for my rig. He literally tossed the keys and took my license and said see you in 30 min, I brought it back in 10 min I was so displeased with the S/C It made driving the truck a chore, since the Taco red lines at 5800, it takes a light foot to literally keep the rear planted, abrupt stabs of the throttle break the trucks composer instantaneously, only throttle lift-off re-gains control making a rather jerky transition to second gear and so forth keeping on the throttle or accelerating to pass on the freeway sends the truck off like a rocket yet watch out as before you know it you have hit the Tacoma's 105 mph governor all and all I found that I was able to drive the N/A V6 with much more precision and control, the S/C breaks the naturally near seamless power band, and turns it into a rodeo act, moreover I found the S/C to be increasingly noisy at any speed in any selected gear, the whine protrudes directly into the cabin and can be quite annoying after a few minutes of motoring. A Toyota service technician also stated that the nut and washer along with the belt on the S/C needs to be replaced every 20k mi! but the cost to do this is quite minimal.
-Personally I would not get it, yet It may have a counter effect supplied on a heavier 4WD crew cab unit, also with an automatic?
-Ryan
See less See more
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (2001TurboGTI)
quote:[HR][/HR]As for the Nissan, 210 hp/246 ft. lbs is not that impressive considering it's supercharged. It's a 3.3 liter sohc 12 valve asthmatic turd attached to an otherwise good truck with a tupperware body kit.
The 3.4 dohc 24v tacoma engine is a much better engine to start with. Add the supercharger and you get 260 hp/~300 ft. lbs. [HR][/HR]​
Yep, IMO the Nissan is just adequate with the supercharger and somewhat underpowered without it.
But the 3.4L in the Toyota is decent to begin with, and with the S/C it is
The TRD S/C Tacoma strikes me as being a mini-Lightning, so I'd say go for it! http://****************.com/smile/emthup.gif
See less See more
3
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (teutonicplague)
Interesting... I would think that TRD would put more effort into their products.
See less See more
Go for it man, I had a 98 v6 4wd, xcab, sr5. Loved it, especially the sound of the engine with the pedal down. If the bugs are out of the SC, then I say do it too. Its a great truck. If you SC it, get ready to buy alot of tires, because even without, it will smoke them with the light rear end. Pretty fun though!!
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (forewheel)
Anyone have performance specs for an extra cab 5-speed with the TRD SC??? What's the 0-60 and 1/4 mile times? Also I suspesct gas mileage to drastically go down...am I right?
I'm pretty sure 0-60 is around 7 seconds, if not a bit less. That's damn impressive for a truck. The TRD kit does have some tuning issues, but by now there are lots of people on the web who have their trucks equipped with the SC so it shouldn't be too hard to find out exactly what you need to do to get it running right.
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (CanuckPal)
I usually get between 18-21 mpg. I'm not sure what the figures are for the S/C. Go to http://www.tacomaterritory.com. Lots-o-info.
See less See more
DO IT!!! I want one myself.
The nissan is pretty dang ugly and it is a sad showing in the performance dept. for a supercharged anything
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (golfSPORT95)
A fellow I worked with had the S/C and TRD exhaust on his tacoma.....very smoof and fast!!
Re: I'm thinking about buying a Tacoma and putting on a TRD Supercharger... (Y2KRICEBOY)
Any issues with the stock clutch, tranny, and transfer case being able to take the extra torque of the S/C???
i think the SC on a 4wd wouldn't melt the 31's on the 4wd tacoma so much mk4ryan, i would agree with the fact that it's probably not the best idea for a 2wd tacoma seeing that it's probably built for towing and torque down low, not 1/4 miles, thus w/o the weight of the bigger rubber and the locking rear differental i could see traction being a huge issue in the 2wd models
1 - 20 of 21 Posts
