1 - 4 of 4 Posts
i have a 1998 jetta 2.0 gl MANUEL and i had to put in a new transmision becasue there was something wrong with it and i changed the machanic changed the clutch since he had to fix the transmision. I had it back for about 2 weeks now and when i shift into second gear somtimes it grinds. THis only happnes when i shift into second.not any other gears.. i dont know why this happnes and it doesn happen all of the time..Is this a common problem with jettas, iS it me?....let me know!!!
Re: IMPORTANT!!! NEED HELP!!!!! (bmwm540)
Could be as simple as an incorrectly adjusted and/or sloppy shift mechanism. It may also be (though not as likely since you noted this is a new tranny) a wore hub and/or syncro. Take it back to the mechanic who did the work. He should be able to find the problem and take care of it for you.
1 - 4 of 4 Posts
