Not sure if anyone else has had this issue after getting a new key programmed at a VW dealership, but hoping to find a remedy to this problem that doesn't require me to purchase/install a new Comfort Control Module...
Took my 2009 Jetta SE 2.5 in to a dealership on Thursday to have a new key programmed (bought the vehicle used about 2 months ago and only came with 1 key). Tried to use the in-door switch for the fuel door release to get gas later that day, but it wouldn't work -- also tested the trunk release next to it, but that also didn't work. Wouldn't have made it home on what I had left in the tank, so had to manually release the fuel door by crawling into the trunk, using the manual ("mafia handle") release the trunk, then manually triggering the solenoid for the fuel door.
Later on, I noticed that when all the doors are locked and I pressed unlock on my remote, it not only unlocks my driver side door, but also my trunk! This also happened when I double-pressed unlock, if one or more of the doors were already unlocked.
I took the car back to the dealership the next day, but they said all they could do was reprogram again. This didn't resolve the issue, so they inspected the vehicle and claimed that I needed a new CCM, which would cost me about $1,000 for the CCM and install labor.
I'm highly suspicious that they might've just mistakenly programmed my CCM for a Golf (or other vehicle with a rear gate), as my power windows and sunroof still work completely fine. I'm logically assuming that a Golf (or other vehicle with rear gate) would likely have their CCM programmed to unlock the gate at the same time as the door -- however, since a Jetta doesn't have a trigger to actually open the trunk, I'm assuming this is why the trunk is popping.
I was already considering purchasing a VCDS interface, so if anyone knows if this is something I can at least attempt to correct through VCDS programming of the CCM, then I'd be eternally grateful if you could also let me know what to do to program it properly for my Jetta. If this in fact is an issue experienced by others that does require a replacement of the CCM, please feel free to point me in the right direction for a DIY for that.
Thanks in advance for any help!
UPDATE 6/2/2018: Also found out that when I use the unlock button on my driver side door, it also pops the trunk along with the door(s) (didn't test to see if this occurred with unlock buttons on all the doors, but will update after I check later).
