Wednesday,25,January,2023,20:56:03:44836
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: 3VWEF81K87M199726 License Plate: 6BFY986
Mileage: 125670km-78087mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEF81K87M199726 Mileage: 125670km-78087miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 S HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9652
Revision: --H01--- Serial number: VWZ7Z0G9031120
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 392F210CD5536083ECC-806C
VINID: 0E69D558805B2077412491C218FF815096
2 Faults Found:
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 125251 km
Time Indication: 0
Date: 2000.00.00
Time: 19:57:06
Freeze Frame:
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 125505 km
Time Indication: 0
Date: 2000.00.00
Time: 18:11:48
Freeze Frame:
RPM: 700 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 30.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.716 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 FL HW: 09G 927 750 FL
Component: AQ 250 6F 0920
Revision: 00H69000 Serial number:
Coding: 0000072
VCID: 00598CE8F609F14BEB2-8054
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B3D324B7BFDAD3E60-8026
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 GG HW: 1K0 820 047 GG
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6FBBDF54DB97FE33028-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000647201
Coding: 14058E234004150007140000001400000008730B5C0000
VCID: 6B83CB44EF8F02132E0-803E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 160607 020 0501
Coding: 00038805
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 69 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M024SLB
Coding: 0013881
VCID: 6C81C858EA81052B27A-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME19427907A
Subsystem 3 - Serial number: 6342MSME131508561
Subsystem 4 - Serial number: 6351HSME0D3A2F60G
Subsystem 5 - Serial number: 6361HSME0D7C183BN
Subsystem 6 - Serial number: 63727SME0D190D062
Subsystem 7 - Serial number: 63827SME0D190843%
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0010021
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 953 P HW: 1K0 920 953 P
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9031120
Coding: 0023207
Shop #: WSC 26101 444 89165
VCID: 38292408EE59798B132-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 060507F1000424
Coding: 3FBF034007001002
VCID: 2F3B1F541B17BE33428-807A
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1610
Shop #: WSC 62481 004 1048576
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000563978525
Coding: 0001205
VCID: 3B233B04DF6F5293FE0-806E
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 125653 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 34311038F2319DEB3FA-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: A_ KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F887F86081B0904058FB0880F0488DCA0
VCID: 045180F8E211ED6BCFA-8050
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000556278531
Coding: 0001204
VCID: 3C213818DA6155ABF7A-8068
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7G6267409
Coding: 0040401
VCID: 1E65D2906CBD27BBF9E-804A
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
01044 - Control Module Incorrectly Coded
000 - -
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000001685898
Coding: 0001168
VCID: 3E253210CC7D47BBD9E-806A
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0440
Coding: 0100101
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000001684355
Coding: 0001168
VCID: 3FDB4F14CB774EB3D28-806A
2 Faults Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 100
Mileage: 125589 km
Time Indication: 0
01554 - Motors for Central Locking; Rear Doors; Lock
Freeze Frame:
Fault Status: 01111100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 125589 km
Time Indication: 0
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.3V)-----------
42-Door Elect, Driver -- Status: OK 0000
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 125251 km
Time Indication: 0
Date: 2000.00.00
Time: 19:57:06
Freeze Frame:
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 125505 km
Time Indication: 0
Date: 2000.00.00
Time: 18:11:48
Freeze Frame:
RPM: 700 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 30.0°C
Voltage: 13.716 V
Coding: 0000072
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 00000
Coding: 0013881
1 Fault Found:
Coding: 0010021
Coding: 0023207
Coding: 0001205
Coding: 0001204
Coding: 0040401
2 Faults Found:
011 - Open Circuit
000 - -
Coding: 0001168
Component: RDK 0440
Coding: 0100101
Coding: 0001168
End----------(Elapsed Time: 01:18, VBatt start/end: 14.1V/14.1V)-----------
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 125251 km
Time Indication: 0
Date: 2000.00.00
Time: 19:57:06
Freeze Frame:
RPM: 2503 /min
Load: 79.6 %
Speed: 96.0 km/h
Temperature: 66.0°C
Temperature: 34.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 125505 km
Time Indication: 0
Date: 2000.00.00
Time: 18:11:48
Freeze Frame:
RPM: 700 /min
Load: 25.9 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 30.0°C
Voltage: 13.716 V
Coding: 0000072
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 00000
Coding: 0013881
1 Fault Found:
Coding: 0010021
Coding: 0023207
Coding: 0001205
Coding: 0001204
Coding: 0040401
2 Faults Found:
011 - Open Circuit
000 - -
Coding: 0001168
Component: RDK 0440
Coding: 0100101
Coding: 0001168
