1 - 7 of 7 Posts
I'm wondering whats the right way to grease the bushings in the front end. When going over speed bumps slowly i hear a sqeeking from the front passenger corner. also when parked if i get out and push down on that corner i can get it to squeek. I've searched and found people recomending to greese these bushings but not really sure where they are and what the procecdure is. Thanks
Re: in need of help with greasing front bushings, squeek over bumps (kremserc)
There is a DIY in the link in my signature.
Re: in need of help with greasing front bushings, squeek over bumps (VgRt6)
thanks, exactly what i needed. Well now that i think about it, would this be considered warranty work?
When i had squeeking noise it was my lower control arm bushings. I sprayed some White lithium grease and it goes away. Comes back every oil change though...heh. Changed them out for new ones, problem solved. Good Luck.
I would think it would be covered by the bumper-to-bumper warranty.
call your local dealership service dept. and ask them.. otherwise just grease them up...
no grease will not last long at all. My friend who owns a garage and we used powder grahite laste year and i have not had a squeak since. You could also try grahite paste and rub it on with a brush either way will work and not flush out when done right
1 - 7 of 7 Posts
