1 - 3 of 3 Posts
my rabbit won't start. it gets fuel and spark, and will start on ether, but it won't stay running. the injector o-rings are kind of loose. would this cause enough of a leak so that the car won't start?
Re: injector o-rings (lucas)
I doubt that bad o-rings would cause this. Since they are pretty cheap and not too difficult to change, why not change them and remove them as a question.
From what you described, it sounds to me like you are not getting proper fuel.
Obviously you have spark, since it starts and runs till the ether is used up. If you were getting fuel, it should continue to run.
Good luck,
fat biker
1 - 3 of 3 Posts
