To answer my own question for everyone else's sake, the wire you would want to use for your "remote turn on" is in the harness for the external CD changer, if your car has one that is. Other than that, I wasn't able to find a wire in the head unit harness that turned on only when the ignition is on or accessory mode. I have a 2006 VW Passat 3.6L with the premium 7 head unitThe new harness from enfig doesn't come with the blue remote wire that goes from your fusebox to your amp. I've been told that you would need to solder your remote wire onto the red wire in the harness to allow the amp to turn on only when the ignition is turned on, is this true? Should I solder the remote wire to the red wire in the harness?
EBayYeah.... this product is discontinued on the website.... are there any other places to get the wiring unit? also is there a cheaper way to do it? or do you have to buy this unit? thanks.
