Tonite I installed some relays on my '84 4K (w/ 4 sealed beam headlights) and I didn't see any difference between the 'before' and 'after'. I used two relays per side (obviously one for low beam and one for high beam) and didn't have any probs w/ the wiring until it came to the grounds. I scratched my head for awhile then spliced both grounds going into the relays into the ground wire looped into the headlights. I wired up one side and compared it to the other w/out and they looked the same. Now when I put in relays on my Corrado it was a big difference between the 'before' and 'after'. Is there something really obvious I'm missing or did I wire the grounds wrong? Any help would be greatly appreciated!
Brian
Brian
