Engine 1.8 8V, CBR 900RR carbs, stock ignition, centrifugal dizzy with vacuum advance unpluged, mechanical fuel pump with fuel restrictor to carbs. | | | | | |
Number of test | slow jet size | idle screws turns out | main jet size | Needle jet height | Results |
1 | 40 | 3 | 155 | standard | Good idle, no throttle response and low power with bad revving, running hot and too lean |
2 | 40 | 3 | 165 | standard | Good idle, no throttle response and low power with bad revving, running hot and too lean |
3 | 40 | 3 | 180 | standard | Good idle, no throttle response and super bad revving and no power at all, really bad MPG, super black spark plugs with carbon fouling, running super rich |
4 | 50 | 1.5 | 165 | standard | Bad idle, better throttle response and better revving, feels a bit of power, bad MPG, black spark plugs with carbon fouling, running rich |
5 | 50 | 1.5 | 155 | standard | Bad idle, better throttle response and better revving, feels a bit of power, bad MPG, black spark plugs with carbon fouling, running rich |
6 | 50 | 1 | 155 | standard | Better idle, better throttle response and revving, feels more power, better MPG, spark plugs with light carbon build up, running rich |
7 | 50 | 3/4 | 150 | standard | good idle, good throttle response and revving, feels more power, better MPG, spark plugs with light carbon build up, running rich yet |
8 | 50 | 1/2 | 150 | standard | good idle, good throttle response and revving, can feel the power, nice MPG, spark plugs with very light carbon build up almost unperceptible, running almost normal |
| | | | | At this point i get an AFR narrow band gauge, the numbers at idle was oscilating between 14.3-14.6, at WOT oscilating between 12.3-13, maybe use a 140 mains play with needle heights and see what happens |
9 | 50 | 1/2 | 140 | standard | good idle, good throttle response and revving, +-25 MPG, spark plugs with no carbon build up, running normal, 14.3-14.6 at idle, 13-14 at WOT |
| | | | | After around 200 miles of driving the spark plugs shows very little carbon build up may be caused by the combination of slow and main jets at middle range throttle so the slow jet was replaced with a 45 size |
10 | 45 | 2 1/2 | 140 | standard | Not yet, check pending |
| | | | | After driving around 100 miles take out the plugs and it seems OK no carbon build up at all, wet or oil. I think i get the correct AFR mixture, got a decent MPG (~4.5 gal in 100 miles) so i decide use this setup permanently. |
