This friday I plan on installing front Mintex pads, refacing rotors, and installing a set of SS brake lines. Couple of questions on this though.
What is the best way to bleed the brakes? Both order to bleed, and how? The only real problem that I see is the lift we have lifts the chassis not at the wheels, so the rear proportioning vavle is going to be closed a lot since the rear tires are going to be hanging down. Has anyone been able to bleed them from the ground? (H&R sports springs lowered)
Also what is the best way to break in these pads? I basically hear to do light braking for the first couple hundred miles or so. Sound good?
If you have any other tips on this they will be appreciated. Thanks for the help.
