1 - 6 of 6 Posts
Sup guys,
Just a quick question if the stock bolts are R12's for the R32? I doubt they are and think they are R13's but i'm not sure. Anyone know the correct bolt size (R12 I believe) and format I need for the OZ's?
Thanks!
Devin
Adding picture of a wheel for all you visual people.
Modified by djdub at 11:54 AM 3-17-2008
· Vendor
Re: Installing the OZ's tomorrow, Bolt Question? (djdub)
VW uses a 14 x 1.5 x 28mm ball seat bolt on all of the 5 lug applications, most aftermarket wheels will require the same length bolt in a conical seat version.
If new lugs were not provided with the wheels, I'd measure how far a stock lug goes through as some aftermarket wheels do require a slightly longer bolt depending on how much pad mounting material is there, but you will want a conical seat bolt unless they are an OEM wheel from another manufacture (ex. Porsche).
We do have a large selection of both ball seat and conical seat bolts available in various legnths, here is a link to everything available for your application:
http://www.ecstuning.com/stage...Bolts
Discussion Starter · #6 ·
Re: Installing the OZ's tomorrow, Bolt Question? (sbvwfanatic)
I got my Ultraz used from someone in the bay. They were custom painted as well. Anyone with OZ's know what bolts you are running? Thanks in advance...
1 - 6 of 6 Posts
