Superb condition IE front camber plates. These are adjustable up to -3 degrees of camber according to IE, which is the most of any camber plates that I have come across. These are what you need to dial out your understeer as much as possible to gain traction and put the power down in the corners.
I installed them once only but it turned out that they didn't work with my custom coilovers (which were originally dampers only). They will bolt right up otherwise, and IE can confirm.
These are very high quality camber plates and even comes with a fully sealed strut bearing built right into the top hats.
What you see here is the latest black anodized version. The box shows a 8/3/2021 date from IE. Shipping to US/Canada preferred.
