Intercooler
733 Views 5 Replies 4 Participants Last post by  PhantomDubs
whats a safe pressure to boost with with the stock intercooler?
1 - 6 of 6 Posts
Re: Intercooler (IMNOBUG)
fuel and timing should be yor bigger concerns.An IC upgrade is the mod for when you have run out of other upgrades or you get a bug up your BuTT to either spend some $$$, cut your car up and or lose your A/C. I've run 20PSI through my IC. Volume/heat soak is a better way to decide whats efficciant.
Re: Intercooler (G60ING)
is there an intercooler that goes up front where the A/C is?
Re: Intercooler (Tom - G - ride)
You have to custom work everything and this subject has been beaten down a lot recently. If search doesn't work please scroll make through all of the topics and it should appear. personally I like my A/C som I'm building an air to water IC
cool...thanks....and good luck with yours....
i just want an IC that will go down and infront of the motor....like where the "hole" is in the middle of the RS bumper....cause i wanna get that too....
See less See more
here we go again, can I get a "FMIC" to the top of the board
See less See more
1 - 6 of 6 Posts
