Is 205/50/16 OK to run on an A3 golf lowered 1.5" (no coilovers)
384 Views 2 Replies 2 Participants Last post by  Frankenwagen
I ask, as I don't see it listed in Eric's post.
There's 205/40 and 205/45........but no 205/50.
Is this because it throws off the speedo and stuff? Or because there are issues with rubbing?
I need to know, as I have 2 good 205/50's, and would love to only buy 2 new tires, as opposed to 4 in a different size.
Yes' or No's would be enough
See less See more
1 - 3 of 3 Posts
Re: Is 205/50/16 OK to run on an A3 golf lowered 1.5" (Frankenwagen)
205/50 would throw the speedo off. 205/45 is what you are after. And as long as your wheels have an offset of around 37, they'll go fine without any rubbing.
So, in other words: No.
See less See more
Re: Is 205/50/16 OK to run on an A3 golf lowered 1.5" (Lobstrosity)
front wheels have an offset of 35mm
rear have one of 22mm
so aside from speedo error, there will be physical problems caused by the extra OAD which I have figured at 24.1"?
It lists an OAD 23.8" for 215/40/17, and there are people that run 18"s and 19"s, correct?
Wouldn't they be at least 24.1" OAD or greater?
1 - 3 of 3 Posts
