My g/f bought .:R32 seats for her MKIV GLI a lil while back and over the winter, I plan on getting the "heated" part working. I've already purchased the in dash switches, and also the connectors for those switches and the seats...and with some "back-wiring" as well to make it easier to hook up.
The guy I bought the wiring/connectors off of also sent me a wiring diagram from the bentley I believe. I'm having some trouble figuring it all out.
Ok here's the details. I have 3 pics below labeling the wiring coming out of the 4 connectors (driver and passenger seat connector are both same):
If anyone here has a Bentley, turn to pages 97-708 and 97-709. 708 shows the driver side setup and 709 shows passenger.
Let's get the easy wires out of here first:
The black/white, black/yellow, and thin brown wires coming out of each seat connector go with the ones coming out of the switch connector. The black/white and black/yellow appear to be direct connections according the the bentley. The thin brown however, shows it coming out of the switch connector, and then into a line labeled 'c' (small c), and shows it as a connection between both of the seats. But where does C run off to? If you follow from the passenger side, it starts with the thin brown, going left brings in the thin brown from the passenger seat connector, then picks up the THICK BROWN from the passenger, crosses the page and picks up the thin brown from the switch and then the seat, and runs off...where to?
The driver side thick brown wire also just runs off the page to what is marked 'b' (small b). The passenger side one tho comes out of the connector, and loops thru what appears to be more heating elements. They are labeled Z41, Z33, and Z9, and are the backrest, side bolster, and side bolster 2 heaters. How the hell do I run this?
Finally back up to the switch connectors, apparently the passenger side wires go into one of each of the driver side ones. The driver side has 2 red/grays, 2 blue/grays, and 2 black/browns. One of each of those will connect to the same color on the passenger connector. The blue/gray I'm guessing just gets tapped into the dimmer switch wiring, so this will light up the LED inside the switches. That leaves the red/gray and black/brown. Red/gray goes throug S244 which is a 15A fuse (Fuse 44), then two plus connectors, and ends at a threaded connection? Not sure about that one. Then the black/brown goes thru S5 which is Fuse 5, and then thru a plus connection and then the ignition/starter switch.
Can anyone provide a PDF diagram for this so others can follow what I'm saying? I really want this to work, specially since I spent $60+ on switches and connectors/wiring. Am I missing anything or is it all just connecting stuff?
