1 - 2 of 2 Posts
wsup yall as the topic states i was wondering if it relly was necessary to change to colder plugs or if its ok if i still run the same but just gap them smaller, thanks
Re: is changing to a colder plug necessary when getting chipped? (ioiwin)
isn't the idea behind colder plugs to prevent predetonation? if you keep the stock heat range plugs and gap them smaller (ie electrodes are closer together) you would have an increase in predetonation. you would actually need to gap larger but that would lend toward misfiring. check the 1.8t tech forums for more (better) answers.
1 - 2 of 2 Posts
