1 - 1 of 1 Posts
Discussion Starter #1
Hi Community,
I have an 04 Audi A4 3.0 Quattro which suddenly cut out on me when I was driving. Before it shut off, I noticed it would drive a little sluggish when I would cruise at 40MPH. Then on the highway, when I would feather the gas pedal, it suddenly shut off so I had to restart it so I don't get in an accident. I've experienced this same symptom and car shutting off on me while driving with MK4 Jetta's (when the fuel pump began failing) so I knew exactly how to restart the car without panicking :laugh:. After starting it back up, the CEL and EPC light were on. So I scanned it with VCDS which produced the below output. Disregard the Clutch Pedal Switch error as I have replaced it and never cleared the DTC. After some brief research, I found that the camshaft control solenoids are known to fail on these cars. Before I go replacing them, how can I confirm it is them and not my fuel pump? Would a failing fuel pump throw the same 17468 and 17465 codes? Also, if its the two camshaft control solenoids, should I replace the other two as they would potentially be on their way out as well?
Thanks in advance!
Code:
Monday,14,September,2020,17:35:01:58921
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: [REDACTED]   License Plate:
Mileage: 207600km-128996mi   Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
          67 69 75 76 77
VIN: [REDACTED]   Mileage: 207600km-128996miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 L    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0010
   Coding: 0016711
   Shop #: WSC 63351 000 00000
   VCID: 3E25C0576C69D76B60F-5160
5 Faults Found:
16705 - Engine Speed Sensor (G28)
            P0321 - 002 - Implausible Signal - Intermittent
17947 - Clutch Pedal Switch (F36)
            P1539 - 004 - Implausible Signal - MIL ON
17468 - Bank2; Exhaust Cam Adjustment Circuit
            P1060 - 004 - Open Circuit - Intermittent
17465 - Bank1; Exhaust Cam Adjustment Circuit
            P1057 - 004 - Open Circuit - Intermittent
18011 - Internal Control Module
            P1603 - 008 - Failed Self-Test
Readiness: 0000 1001
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      3429
   Coding: 04495
   Shop #: WSC 06435
   VCID: 2615083791F96FAB08F-51F2
2 Faults Found:
18258 - Powertrain Data Bus
            P1850 - 35-10 - Missing Message from ECU - Intermittent
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 AD
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 63935123A24BDA832F1-5160
No fault code found.
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 63351
   VCID: 3537DF7B5C5F1433B15-4B00
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No: 8E0 035 593 A
   Component: SDAR XM            0010
   VCID: 270B053396C376A3339-5042
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            35-00 - -
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        3000
   Coding: 0010607
   VCID: 372BD5734353E623A39-5184
Address 16: Steering wheel        Labels: 8E0-953-549.lbl
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 02041
   Shop #: WSC 63351
   VCID: 3E25C0576969D76B60F-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 03200
   Shop #: WSC 08102
   VCID: 323DE467AD31030B947-5184
   WAULT68E04A027722     AUZ6Z0C0161327
1 Fault Found:
01314 - Engine Control Module
            49-10 - No Communications - Intermittent
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BF2B6B68877813ADD-4B3C
Address 46: Central Conv.        Labels:. 8E0-959-433-MAX.clb
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72BD24676DB1430B547-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
3 Faults Found:
01134 - Alarm Horn (H12)
            49-00 - No Communications
00955 - Key 1
            35-10 - - - Intermittent
01561 - Rear left door
            59-00 - Can't Unlock
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00060
   Shop #: WSC 63351
   VCID: 045172BF47357DBB76B-4B5C
2 Faults Found:
00774 - Level Control System Sensor; Rear Left (G76)
            28-00 - Short to Plus
00776 - Level Control System Sensor; Left Front (G78)
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 8E0 035 195 H
   Component: symphony II NP2    0260
   Coding: 01205
   Shop #: WSC 07936
   VCID: 2C01FA1F8F2555FBDEB-5042
End----------(Elapsed Time: 05:14, VBatt start/end: 14.0V/14.0V)-----------
1 - 1 of 1 Posts
