Re: Is it possible to upgrade the MAF? (ScrapinSi)
putting an afc in isnt the easiest. can it be done? im sure. but nobody here has done it. a few say they have seen someone with it, or know someone with it, but for the most part, putting it in the 2.0L aba engine is kind of unexplored.
the cost of the 'stang MAF, and the cost of the AFC is pretty high. then if you run injectors.....
most people dont do this because your almost spending the same as like an SDS setup that controlls all your fueling and timing needs.
