by itself (espcially w/ the sandwich style adapter plate setup which SUCKS) an oversize t/b might make the throttle response a bit better, but not much in the way of power gains...however, combine it with a match ported intake manifold opened up to the correct size (drill or dremel with a flexshaft and an asst of grinding stones works quite well, pick up a junkyard manifold or two and do it yourself) can make something like 8-10hp depending on other mods and the condition of your engine...you will definitely need to have your CO and idle reset after the install, but there's almost no downside- my car pulls much harder from idle to redline, revs faster and smoother, and seems to get a few more mpg on the highway..w/ the g grind and some headwork, it used to make power to about 6200-6500rpm then it was choking, now I have to keep an eye on the tach cos' it just keeps making power, at least to 7k, I don't push it past that if I can help it
(i do have h/d valve springs to keep everything in check) if you junkyard everything, it's a great gain for few $$, good luck
