1 - 12 of 12 Posts
changed my oil on the weekend and I noticed this. Could it be due to the engine not getting hot enough, as in not driving the car for any extended lengths of time? Is this more of a winter thing, cuz I never saw this last year. TIA
Re: Is this something I should be worried about... (Capital P)
What is that a pic of? I know that is the upper intake maniford, but the other thing? Did u remove the PCV Valve?
[Modified by Kooz, 1:42 AM 1-27-2003]
Re: Is this something I should be worried about... (scarboroughdub)
quote:[HR][/HR]thats the oil cap and it has monkey jizz on it
[HR][/HR]​
Um, ok? I asked a simple question. No need for the sarcasm.
Re: Is this something I should be worried about... (Kooz)
yeah, it's the oil cap resting on the manifold
i'm not an expert at all
but the fact that your oil looks like coffee+cream colour is bad...
it could be your head gasket.
is the oil this colour? or just the residue under the cap?
Discussion Starter · #7 ·
Re: Is this something I should be worried about... (sanjay69)
the oil is normal colour. I just noticed this stuff under the cap and in the reservoir but it's above the line. I'm thinking it might be moisture building up in that pocket of air between the oil and the cap.
It dam cold and monkey jizz happens b/c of condesation, the engine dosent get hot enough to evaporat the moisture, unless your head gasket is blown,
nothing to worry about for now, ITS TO COLD
Premium Member
Re: Is this something I should be worried about... (V6R)
yep, what he said.
quote:[HR][/HR]It dam cold and monkey jizz happens b/c of condesation, the engine dosent get hot enough to evaporat the moisture, unless your head gasket is blown,
[HR][/HR]​
Discussion Starter · #10 ·
Re: Is this something I should be worried about... (Jouko Haapanen)
thanks guys. I guess I'll have to wait and see.
I've got the same thing my friend. Don't worry. It's harmless! I spoke to my dealer when I first discovered it. Apparently the 'Monkey Jizz' is from not getting the car up to full operating temperature, by way of short trips and cold weather. Hamilton Volkswagen has assured me that this "Jizz' has no ill affects and will cause no harm. So far, no problems, and I don't expect any either. Happy dubbin!
1 - 12 of 12 Posts
