1 - 20 of 163 Posts
Discussion Starter · #8 ·
Someone cut BIG stupid speaker holes in them and also through the door below the cards. I'm going to have to weld a patch.
Also there was the mold, so they went in the garbage along with the seat belts, headliner, carpet, dash etc....
Modified by rabfan at 11:37 AM 5-27-2005
Discussion Starter · #12 ·
Re: It began yesterday (rabfan)
Ok so today I worked the heater box and defrost vent over and got them into place. Holy fabrication Batman!
I soon discovered that in order to locate the box properly, the carpet would have to come out. This was disgusting. I almost puked. I think I ruined a perfectly good pair of Carharts on that stupid dum dum tack they use to secure the carpet.
Anyway, carpet out.
I found this weird thing under the carpet. It's been primed and painted and had glue over it so I guess someone left it in there at the factory. Looks like a paint can handle.
I then located the heater box and marked out the attachment points on the fire wall.
I removed the upper screw and used only the lower one and the one near the fan as my heater core sticks out of the rain tray as you can see above.
The shortened mk2 box.
Only one of the screws goes thru the fire wall near the intake manifold on the passenger side. I made an internal mount and welded it in for the lower screw. My third attachment point is right behind the defrost vent above the firewall.
Box and vent in place.
I located the fan under the rain tray right on a spot that looks like it is supposed to have a hole for a fan or something. I'll cut the hole later.
Cover for the heater core in the rain tray made from the old mk1 heater box.
I must have had the dash in and out 15 times to make sure everything lined up. but it looks good and if it weren't for the seams on the ducts from my plastic welds it might even look like it's supposed to be there.
Later
RJ
Discussion Starter · #14 ·
Re: It began yesterday I guess I can call this a project now. (rabfan)
Cut the hole for the fan yesterday
With everything lined up I'm ready to make the lower brackets for the dash.
I decided on a change of venue for today and removed the front fenders to prepare for the valence change.
I was happy to see that there was only surface rust underneath.
I think I've got the trick down for removing the fenders
RJ
Discussion Starter · #17 ·
Engine/trans, and wiring out. I always forget to loosen the driveshafts first
Anybody want to buy a 4spd transmission? $100
Modified by rabfan at 10:55 AM 6-2-2005
Quote, originally posted by rabfan »
*I remember how fun it was stripping the interior
You did a good job there buddy http://****************.com/smile/emthup.gif
*carpenters knife came in handy
1 - 20 of 163 Posts
