New pic with tires.
Suspension is all done:
New mk3 subframe
New control arms with Energy Suspension poly bushings
New ball joints
New tie rods
New (to me) power steering pump
New VR6 strut bearings
Zimmerman cross-drilled 11" front rotors
Corrado G60 spindles and calipers
New Lobro halfshafts
Koni coil-overs
Neuspeed 25mm front sway bar
Energy Suspension poly bushings in rear axle beam
Zimmerman cross-drilled rear rotors
Corrado G60 rear calipers
Corrado G60 rear axle
Neuspeed 28mm rear sway bar
New e-brake cables
Autotech braided brake lines
Damn camera batteries pooped out before I could get any shots of any of the new stuff
Scott
[Modified by scooterman, 11:00 PM 11-28-2001]
New mk3 subframe
New ball joints
New tie rods
Koni coil-overs
New e-brake cables
Scott
