1 - 4 of 4 Posts
Ok, now I'm not really giving anything away. BUT, I have a very simple question... How do you change the lights that light up the climate controls? Mine don't light up at all and wanted to ask how to do it cause it's the only one I've got and don't wanna ruin it.
Re: It's time to give it away... (xhybrid_dubx)
not replaceable. well, not supposed to be. gotta break it open, cut along hte back where you can see the peices are joined, now the back will come off. time to put in a new bulb, a super-bright green led will do it, or a small 12v light bulb wrapped in green celophane, glue it back together and wire it up.
other option is to buy a new one, or try and find one at a wreckers that is not burned out. or i can search my local wrecker and try and find you one for a few bucks.
Re: It's time to give it away... (The_Hamster)
I think I'll try to replace the bulb. If it doesn't work out then I'll just have to scavange for a new one. No biggy.
should work unless there is a problem with your headlight switch adjuster for inside lights.
1 - 4 of 4 Posts
