i have a SC on my vr6....as i understood it i should be able to tap my vac line for the boost gauge at the FPR with a "T" fitting...i did this and the gauge would not read boost only vac....i then moved the tap in place for the vac line to right after the SC outlet and now the gauge reads boost only....so what am i doing wrong here? thanks, rick
btw its a stewart warner boost gauge from 42 draft designs and it does read both vac and boost in case someone thinks im that dumb....thanks for the help....
