Jacking points and jack stands
8K views 11 replies 8 participants last post by  Timbert
#1 ·
I usually jack the car up from the pinch welds for the tire jack and put the jack stands under a certain point on the subframe.
I would jack the car up from the subframe and put the jack stands under the pinch welds but I don’t have a low profile floor jack.
How do you guys go about this.
#2 ·
There should be two plastic circle covers near the pinch welds behind them, you can pull those covers off and jack it up from there or just leave the covers on if you don’t care about damging the plastic (I leave them on) but it can still be tricky to fit a jack stand on the pinch weld with the jack being on the circle so position the jack as close to the wheel as you can do you can fit the stands
#3 ·
@imran09 you can use something like this jack pad adapter from ECS tuning :Jack Pad Adapter Kit
That will let you lift from the factory jacking points more easily.
Alternatively, you can do something much cheaper and jack from the pinch weld using a hockey puck with a channel cut into it, or a prefabricated one like this: Universal Jack Pad Adapter
I usually put my jack stands underneath the control arms-there is a flat spot underneath them that works well.
Good Luck!
#4 ·
Good Luck!
Won't jacking from the control arms damage them?
#8 ·
I've got a pretty heavy duty jack that I use in the middle if the car(where the front and rear doors meet) I use a ECS universal jack pad adapter and lift on the pinch weld, then I put the jack stands at the factory jack points. This method allows me to get all 4 wheels off the ground by only having to jack the car up twice. Any descent 3 ton floor jack should be able to easily lift up half of the car at one time.
