1 - 20 of 110 Posts
Thanks to Andrew at ORT I bit the bullet and ordered bagyards.
Getting started on my trunk and management setup while I wait for the bags to get here from germany. Should hopefully get here around middle of February.
False floor is pretty much done. Still need to mount everything, run/cleanup the wiring, get notched, and run lines when the bags come in.
Autopilot Mock-up by JAK-RBT, on Flickr
JAK-RBT's Air Ride Build by JAK-RBT, on Flickr
Discussion Starter · #16 ·
Discussion Starter · #18 ·
interested in your choice of compressor. I've read a few reviews and they all seem good :thumbup:
Since I'm going for a setup that I can hide-away I had to use a small 3 gallon tank. That means my compressor will probably kick on pretty often, so I wanted something that would fill quickly. Again, since space is limited I didn't want two compressors, so I went with this beastly AZ OB2. I too have read some good reviews
Discussion Starter · #19 ·
hacked the living hell out of my ash tray and finally came up with a way to mount the controller that im happy with. (don't mind my hack job, already order a new tray)
Lid closed
Controller hidden
Lid opening, controller creepin
Lid opened. Controller hinge mount
Controller tilted up and locked in position
Lid closed
Controller hidden
Good job, that's gonna look dope :cool:
1 - 20 of 110 Posts
