1 - 4 of 4 Posts
Group 2 but I think groups 1-4 are the same. Unit works perfectly, I just took it off because I tuned. I also have the old JB1 board that I will include because I can’t use it. I started with the JB1 and then upgraded but I guess you could also downgrade this unit and run it as a JB1 if your on the fence because the JB1 installs simpler and leaves less evidence. Then you can upgrade to the JB4 board if you want the better control.
SOLD
Ac adapter Adapter Adapter Circuit component Electrical wiring
Are these devices coded to a vehicles VIN or anything? Or can they be freely swapped from one vehicle to a different one?
These can be swapped from vehicle to vehicle as they are not vin locked but they can only work on one vehicle at a time as they have to remain hooked up
Sent you a PM.
1 - 4 of 4 Posts
