Hello,
I have a 2000 Jetta, VR6, engine code AFP. The check engine light has been on for a while, with error code P1395. Replaced the ignition coil and the spark plugs, but the same error code remains.
I purchased a vag-com and just ran the autoscan ... codes returned are listed below. I am looking thru the bentley manual and trying to determine what may be causing these codes ... haven't gone thru the test procedures yet from bentley, but will be doing that over the weekend.
I have a new ignition wire set, but haven't installed it yet. The old wires check out within acceptable resistance (~6.2 kOhms) from end-to-end, but after replacing the coil and the plugs (and still getting the same error) I figured the wires might be the cause.
I believe the airbag and passenger window errors are unrelated to the check engine light, but included them below to be complete. I guess I was wondering if maybe someone on the forum has encountered the engine-related errors before.
Thanks,
Zac
Errors:
Address 01: Engine
Part No: 021 906 018 K
Component: MOTRONIC ME7.1 G V04
Coding: 00033
Shop #: WSC 00066
2 Faults Found:
17803 - Ignition Coil Power Output 3: Electrical Malfunction
P1395 - 35-10 - - - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Readiness: 0000 1001
Address 15: Airbags
Part No: 6Q0 909 605 A
Component: 09 AIRBAG VW5 0003
Coding: 12345
Shop #: WSC 00066
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 46: Central Conv.
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
Part No: 1J1959801C
Component: 61 Trsteuerger. FS0002r
Part No: 1J1959802D
Component: 61 Trsteuerger. BF0002r
Part No: 1J4959811C
Component: 61 Trsteuerger. HL0002H
Part No: 1J4959812C
Component: 61 Trsteuerger. HR0002r
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Thanks,
Zac
Errors:
Address 01: Engine
Coding: 00033
Shop #: WSC 00066
2 Faults Found:
P0420 - 35-00 - -
Address 15: Airbags
Coding: 12345
Shop #: WSC 00066
1 Fault Found:
Coding: 04096
Shop #: WSC 00066
Part No: 1J1959801C
Part No: 1J1959802D
Part No: 1J4959811C
Part No: 1J4959812C
1 Fault Found:
