1 - 14 of 14 Posts
Banned
Ok.... I started her up this morning she satrted 100% fine i was warming her up
i went back outside to leave.. and it stalled.. i start it back up starts find then dies..
start up then dies start up then dies...
if i satrt it flooooor the gas it sputters at like sooooo low rpm's just over the 0 but the battlight is flashing etc..
sigh
any idea what i can check or what it could be?
Re: Jetta keeps stalling.... Help pls (Tbird Pimpistik)
Sounds like a vaccum hose popped off or your intake has a tear or crack in it. Any its a big vaccum leak and it's getting unmetered air. Good Luck.
Banned
Discussion Starter · #6 ·
Re: Jetta keeps stalling.... Help pls (MyBlackGti)
not funny.. ..
its running 100% fine now but i mean i checked for rips in the boots i see none..
what could it be?
dizzy cap/rotor?
a sensor??
dunno if im right or not but a similar thing just happened to my dub. turned out that alternator wasn't puttin out as much as it was supposed to. batt light wasnt flashing but it was dim. so switched the alternator and bam its running like a dream
Banned
Discussion Starter · #8 ·
Re: Jetta keeps stalling.... Help pls (mk2vdub)
mmm i dont think its the alt
thanks thou...
the reason the batt light came on was cause it was about to stall at 200 rpm's or so... seems ok now..
mmmmmm
keep an eye on it i guess......
sigh
a few things to try/look at:
vacuum leaks
in tank transfer pump(is the gas level low?)
additional ground from ICU/ECU to chassis per PAGTI91's suggestion.
Banned
Discussion Starter · #10 ·
Re: Jetta keeps stalling.... Help pls (vwtoys)
hmm whats odd also is
sometimes when i start it its not 100% smooth running for the first few seconcs, its like its being bogged down a little low idle then normal and kinda a tadd rough then the idle wil jump up to 1000 like its getting a breath of fresh air then it drops to normal 950ish
hmm
but this was much worse
i checked for vacum leaks and found none hmm mabe i out to take em all off and examine closely..
sigh thx for al ur help
hope itll be ok
Banned
Discussion Starter · #14 ·
Re: Jetta keeps stalling.... Help pls (VW-BMW)
ok it almost did it again
i started it up was driving fine etc idling for like 2 hrs now i satrted it up
it kinda hesitated a bit like a taddd misfiring taddd
i gave gas nothing then suddenly it shot up and was fine
hmmmmmmm
i have new plugs in there.. any ideas?
1 - 14 of 14 Posts
